How to Turn Off Telephone Line Monitoring, DSC Power 632
Old 12-21-14, 08:02 AM
E
how can I turn off the beeping notice that my phone line has been disconnected, on a "DSC Power 632" ?
The alarm system is working fine except that when i turn it on, it eventually starts to beep at regular intervals to let me know that the telephone line has been disconnected. I do not have the option to reconnect the telephone line so I am very hopeful that you can find a way to program it such that there is no telephone monitoring service.
Thank you
Eddie
Old 12-21-14, 08:43 AM
Enter programming: *8 (installer code)
Go to section 015. Turn off 7. # # out of programming.
This turns off telephone line monitor
Installer code default is 1555 I think on these. Other option would be remove telephone numbers in section 301 and 302. This will keep you from seeing a trouble if it tries to call out.
Old 12-21-14, 08:53 AM
E
thank you so much jdh79. Sorry but I probably should have mentioned that the key pad is the
PC1555RKZ (installed and programmed 10 years ago in 2004)
I think I can get as far as getting to section 015 but I do not know what to do to after that to turn off 7.
Also, I found a manual online that says the section number is two digit such as 15 and not 015. However, i do not know if the two digit section applies to my system or not.
Old 12-21-14, 09:09 AM
Received 88 Votes on 83 Posts
Installer manual: http://www.sentinelsecurity.com/sssm...n%20Manual.pdf
You may be looking at a manual for a PC1550.
In any case, with option selections the zone LEDs light to indicate if an option is turned on or off, which is why they are grouped in groups of 8.
When you go to section 015 the zone 7 LED will be lit if the TLM option is on. When you press the 7 key, the LED will turn off. Then press # to accept the change.
The programming syntax instructions are in chapter 4 of the installer manual.
