Ademco 5828 keypad
Old 12-22-14, 01:15 PM
L
Received 1 Vote on 1 Post
Ademco 5828 keypad
Are there two kinds of 5828 keypads - one for battery operation and one for electrical ? Mine is currently working with 3 batteries but I don't like how it doesn't stay lighted and how we have to hold down the '*' key to wake the keypad up. Yet when I open the keypad up I don't see anywhere to attach an adapter.
Thanks and Hapy Holidays !
Old 12-22-14, 02:00 PM
T
Just the one 5828 keypad using either transformer or batteries -- your choice. Transformer plugs in the back.
edit: Even plugged in, I do not believe it stays lighted but, you don't need to wake it up [like on batts].
Old 12-22-14, 02:02 PM
Is this mounted on a wall?
There should be a jack for the power supply on the back, not under the battery cover but next to it, kind of in a slot facing downward and has a wire trace for the wire to fit flush with the wall going downward.
https://www.alarmgrid.com/products/honeywell-k0991
I can't find a picture of the back but the above link is the correct transformer.
Old 12-22-14, 02:04 PM
Received 89 Votes on 83 Posts
There's a kit for that that provides the plug in power supply and optional deskmount. The plug in connects in the little divot to the left of the battery compartment.
http://www.gargoylesecurity.com/Down...pdf%5B1%5D.pdf
http://www.slideshare.net/alarmgrid/...dminstallguide
Whether powered by battery or AC, these keypads still have a bit of a lag on "wake up".
Old 12-22-14, 02:27 PM
L
You guys are great ! Yes the keypad hangs on the wall. I had been looking at the top surface of the circuit board but I now see on the back where the adapter attached.
I have a box of adapters I've held onto over the years. I have one in my hand which says : Class 2 power source. Input 120VAC 60HZ 5W. output 6VDC 300 mA.
Think I can use it with the 5828 keypad ? It connects fine to the pin on the back.
Old 12-23-14, 03:49 AM
L
Answer to self - no.
The k0991 adapter is cheap enough at around $14-20 USD. It just hurts to pay as much as $35 to have it delivered to Mexico.
Thanks again.
Old 12-23-14, 07:47 PM
T
It is a 5vdc trans, not 6vdc [not sure of amperage]. just check a Goodwill [or similar] store - make sure your polarity is correct. if reversed, just cut the wires and reverse them.
