Connecting two 260-co detectors
Old 12-30-14, 06:59 PM
K
Can anyone provide assistance connecting two 260-co carbon monoxide detectors? The instructions are clear on how to connect three, but there are connections from the first and the second detectors to the third. Confusing to me.
Old 12-30-14, 07:19 PM
Received 1,030 Votes on 956 Posts
Are you putting two sensors on one zone ?
Better to put them on two zones if you have a spare available.
Old 12-30-14, 07:22 PM
K
Unfortunately I only have one zone available. I am replacing two 240-co detectors that are wired in tandem on that zone.
Old 12-30-14, 07:34 PM
K
The 240-co's were simple: + to +, Gnd-Gnd, Com-Com and NO-NO with an EOL resistor bridging the NO and COM on the second unit.
Old 12-30-14, 08:10 PM
The only problem with that method is that the units weren't truly supervised. That's why the change in wiring. Now you'll need an additional conductor between the two detectors for a total of five.
The red and black are power. The gray and blue are your zone wires. If you notice.... the NC switches just form a loop that is connected across the zone wires.
Old 12-31-14, 05:53 AM
K
Helpful diagram. I'll need to run another wire it seems. (Is there no way around that?) I notice the EOL resistor is on the first unit. On my other devices (heats, smokes) it is on the last unit in the series. Does it matter? Does the green wire bring the loop back to the first device?
Old 12-31-14, 08:00 AM
The loop goes thru both units so the resistor can go at either unit. There really isn't an end of line. The resistor basically supervises the loop.
Old 12-31-14, 04:43 PM
K
Got it. Thanks so much for the help.
Old 12-31-14, 10:37 PM
T
I believe you can get the same effect by running one leg of the alarm circuit through the N/C relays and putting the EOL on the N/O relay of the second ℅ detector -- that way you don't need the extra wire.
[Or possibly running a leg of the power through the N/C relay -- if the N/O relay changes state w/o power].
