dSC 1616 PGM delay.
Old 04-16-15, 11:41 AM
B
dSC 1616 PGM delay.
Hi,
I have a pgm 1 programmed *8 5555 009 05 01 and when armed/disarmed i got it a delay on approx 10-15 min before anything happens on that port.
What have I missed here?
I would like it to be instant aknowledge or maybe 30 s.
Regards boz
Old 04-16-15, 03:39 PM
If your programming is correct, PGM-1 should change state as soon as the arming delay ends.
Old 04-16-15, 10:59 PM
B
It's a old installation that I never made, is there some parameters that I could check?
Old 04-17-15, 03:58 AM
The only real variable in this is the length of the arming delay.
Old 04-17-15, 09:10 AM
I guess you have a NO/NC relay wired to the panel where it is powered through PGM-1 (ground) and Aux+ (12V DC). Could it be that the unwanted delay comes from the relay instead of the panel? There's actually in the market relays that you can manually delay the switch between 0 and n seconds.
You can perhaps start to measure the voltage between PGM-1 (ground) and Aux+ to make sure there's immediate power upon alarm triggered. If it does then the delay is to be found at the relay side.
