DSC keypad section 080
Old 05-09-15, 03:11 PM
I have an RFK5500 keypad, trying to use the P/Z as an output to light an LED when the alarm is set. Have an LED wired to the R and P/Z so that it should allow it to light but it isn't and I'm guessing I'm missed the setting for 080 but can't find the definition
I have the keypad section 077 option 3 on that should make the PGM an output.
What I can't figure out is what does 080 need to be set to for that voltage to be on (or circuit closed) when alarm is set?
thanks
Old 05-09-15, 07:46 PM
Received 92 Votes on 85 Posts
80 is where you set the PGM number, After that you program the PGM setting in the main system programming.
If you set it as PGM 03, then the PGM programming is set in programming location 010 (this is assuming that you have a PC1616/1832/1864).
Old 05-10-15, 06:12 PM
Ron,
1832 correct
080 as you indicated sets PGM, so then, why set to 03 vs 01?
Once set to 01 or 03, then where do I set the PGM setting so it allows the p/x set to output to apply as an output?
Old 05-11-15, 02:32 AM
Because the two main board PGMs are 01 and 02. If you don't plan to use them, at all, then it would not matter, of course, which address you picked.
Installer manual: http://cms.dsc.com/download.php?t=1&id=17007
