vista 20P alarm panal
Old 06-06-15, 02:06 AM
I am helping my brother install a new vista 20P alarm panal.
We have a new panal, and a 6160 keypad.
Our issue is that none of the wires at the panal are marked as to what they are for, doors, windows, Etc... I have hooked up alarms in the past but I don't know how to test each zone to see what it covers.
thanks,
John
Old 06-06-15, 04:40 AM
Received 241 Votes on 220 Posts
With a prewire like this with no markings on the wires, the only way to do it is to put a ohm meter or other continuity tester on each pair, and open each door/window until the that pair opens. If there aren't contacts in place, you could use a tone generator and sniffer.
There's no magic bullet for this. A place with a lot of openings can take 2-3 hours to just identify the openings.
Old 07-07-15, 04:17 PM
C
I'm about to swap out an old Vista 20P with a new 20P rev. 10.23 chip. I think the older panels require keypads 6150 or 6160 for programming. I thought I read somewhere that the newer revisions allow you to program with graphic interfaces, but not positive.
In the back of the Programing Guide (5/11 Rev. C) it list compatible devices:
Keypads
6150
6160
6272
6280
Tuxedo
1) Can it be programmed with any/all of these?
2) will the older 6271 keypads still work, because they aren't listed as compatible?
Thanks!
Old 07-07-15, 06:02 PM
Use the 6160 for programming. The touchpad models can be used as a programming interface; but there is a lot of lag in that interface; so programming more than a couple of changes is pretty frustrating.
Old 07-07-15, 06:20 PM
C
Thanks!
I assume my old 6271 keypads will still function after Programing, eventhough they're not listed.
Old 07-08-15, 02:28 AM
Yes, it should work. The 6272 is just the more recent version.
