DSC 1864 Alarm, strobe light for each partition?
Old 07-28-15, 04:06 PM
G
I am trying to set up separate strobe lights on an alarmed building with 2 partitions so I can see which partition is in alarm before going inside. According to the PC1616/PC1832/PC1864 v4.6 NA Installation Guide, I should be able to do this. Older versions (3.2) of the guide state very clearly: This output [10] will activate when the programmed events occur on any partition. On the bottom of page 12 of the version 4.6 guide it states: PGM Output Options: [10] Latched System Event (Strobe): Output will activate when a selected condition occurs on any selected partition.
Is there a way to indicate which partition is in alarm? PGM Output Option [30] comes close to what I want but, I don’t want the strobe active when the partition is armed; only when it is in alarm and until it is disarmed.
Old 07-28-15, 06:30 PM
See programming options for sections 501-514 and 551-564. There are so many selections depending on how you set it up but give it a good read thru
