5820 with Vista20P armed for Away only
Old 08-18-15, 10:20 AM
I am installing from 5820Ls in our bedroom. The wife and I like to leave the windows open at night for coolness and fresh air. I would like to set the 5820s on the windows to be disabled when in STAY mode but active in AWAY mode.
Is this accomplished by setting the loop number from 1 to something else (i.e. what?), setting the zone type to something other than perimeter (i.e. what?), or another way?
Thanks in advance.
Old 08-18-15, 12:16 PM
Would setting it in the Vista 20P as a motion detector work?
Old 08-18-15, 12:25 PM
You would do that by programming the zones in question as a interior follower (zone type 04) or by using a customized zone type, or by simply putting another magnet at the position that the window would be open to. The loop number doesn't enter into this.
Honestly, for what you really seem to want to do, the last option is the simplest. You just have to remember to open the window to the same position each time.
Old 08-18-15, 01:09 PM
Its very simple, as MrRonFL said, just add an other magnet.
Old 08-18-15, 01:17 PM
I forgot to mention that they are casements :-( Not sure how a second magnet could work with those...
Old 08-18-15, 01:29 PM
Actually a custom zone looks like this may do it. ;-)
Old 08-18-15, 02:21 PM
Hmmm, with casements, then you either use the interior zone type, create a custom zone (a "vent" zone configuration would do what you want) or get into the habit of using the zone bypass feature.
Vista panels have a fairly limited choice of zone types...
Old 08-18-15, 05:44 PM
Yep Vent looks like it may just do it...
Time to test the limits of my monitoring companies patience ;-)
Thanks for everyone's response!
Old 08-25-15, 06:34 PM
Hrm...not sure I want vent.... so configurable zone may be it. Any comments on this config?
Remember its a wireless 5820...
Entry 1: 0
Entry 2: 3
Entry 3: 0
Entry 4: 11
Entry 5: 0
Entry 6: 1
Entry 7: 0
Entry 8: 8
Entry 9: 6
Entry 10: 6
Feedback appreciated...Thanks!
Old 08-26-15, 09:23 AM
What are these?
Entry 1: 0
etc.
Entry 1:? Are these zones and you have 10 different entry zones?
Then what is the number following each? Zone types? ??
Old 08-26-15, 10:27 AM
He's referencing the configurable zone table on page 4-12 of the installer manual: http://www.nationwidesecuritycorp.co...all-Manual.pdf
The entries set up how the configurable zone works. Once it's set up, you use that zone type for the zone programming in *56.
Old 08-30-15, 06:27 PM
Mr Ron,
Any thoughts on those values? Input appreciated ;-)
Old 08-31-15, 03:06 AM
Give it a shot. If it doesn't work quite right, you can always change a couple of settings.
Old 09-01-15, 03:31 PM
Turns out a Zone 04 (Internal follower) worked fine and did exactly what I wanted it to... so there was no need to go custom. Thanks for everyone's input.
