ADT safewatch 3000 master code
Old 09-02-15, 07:00 PM
Just purchased home that has a pretty detailed system. Appears that it works, but prior owner either did not have or just would not give us any codes. Shows active, ready to arm. I've been reading and tried numerous codes. So far none work. Is there an easy way to reset master or installer code? I do know I need to get a alpha display before doing much. But wanted to test system before spending a lot. Thanks
Old 09-02-15, 09:46 PM
Use the installer code to create a new master code -- No alpha needed.
Old 09-03-15, 04:27 AM
No installer code is working. I was able to power down and back up yesterday, will see if I can use info I found to set master
Old 09-03-15, 04:41 PM
Thank to those that posted earlier about resets. Worked perfectly. Powered down, #20 gave me the installer code, yes, leading zeros, and the same number repeated 3 times threw me off for a while, but reset master easily after *99 and then installer code 802 and my new code. I can at least set alarm now at night and reset alarms.
