Can not clear fault.
Old 09-07-15, 04:59 AM
Ademco Lynx alarm system wireless door sensor 03 fault. Removed door sensor to change door casing. Can not remove fault from the system. Can bypass okay. Tried [code] + 1 then (off) several times. Changed batteries. Alarm sounds when removing battery. Checked contact on cover to make sure it was aligned. Thought that could be the problem. Reviewed a lot of the threads looking for answers. Need some help. Any suggestions? Thanks.
Old 09-07-15, 07:11 AM
Was able to clear fault and system working. Rechecked cover connection and bent metal contact to ensure contact. Had to try different location of the sensor above door magnet.
