Changing from my brinks bhs 400a
Old 10-06-15, 08:47 AM
Yes, typically you would use a perimeter zone type for glass breaks.
Old 10-06-15, 08:52 AM
Received 25 Votes on 24 Posts
In general, perimeter is fine.
  #43
Old 10-06-15, 04:44 PM
Great. Thanks.
I got my 8 pin connector today and I was trying to connect my 4 conductor wires smoke detector but I am confused with the color of the wired on the 8 pin trigger connector.
I see red on left pin, empty, Orange, yellow, green, blue, purple, and black in this order. I connected the trigger connector to my panel, connected red to black of smoke detector, Orange to positive aux of panel, green of smoke detector to terminal 8 of panel, and yellow of smoke detector to terminal 9 of panel. I did the programming of *79 and *80 correctly. There is no power in the smoke detector. What am I doing wrong?
  #44
Old 10-06-15, 06:19 PM
The + power for the smoke goes to Aux + The - power for the smoke goes to output 17. The orange wire on the connector is a +12V _output_...
  #45
Old 10-06-15, 07:05 PM
So in my case, is red my output 17?
  #46
Old 10-07-15, 02:13 AM
Yes, just like the diagram on page 2-4 of the installer manual.
  #47
Old 10-07-15, 04:55 AM
Thanks MrRon. Can I hook my second smoke alarm to the same output 17 and use zone 1 as well?
  #48
Old 10-07-15, 05:58 AM
Normally, multiple smokes are connected on the same loop. If yours was originally setup as multiple 4 wire smoke zones, they would all have individual zones, on any zone input _except_ zone 1 (which needs to be for 2-wire smokes if it's programmed as a fire zone).
  #49
Old 10-07-15, 06:07 AM
MrRon, I just happen to look deep down the forum and saw one of your posts saying a 4wire smoke alarm cannot be used for zone 1. And yes, ADT did not install the 2 smoke detectors in loop.. Dunno why, but now I know that I need to go back and use zone 2 and zone 3 for my smoke detectors. They can share the output 17? right?
  #50
Old 10-07-15, 07:57 AM
Yes, they can share. In this usage, output 17 is just a switching ground.
