DSC Impassa Disable Away Exit Beeps
Old 09-22-15, 08:08 AM
I cannot figure out from the manual how to disable the Away exit beeps. I want it to be a silent exit when arming for Away....
I thought it would be section [014] - 6 ...
Can anyone provide the right section for this setting?
Thanks!!
Old 09-22-15, 09:33 AM
The manual section 3.1.1 -Away Arming says:
If the Audible Exit Delay option is enabled, the keypad beeps once every second during the exit delay (and three times a second during the last 10 seconds) to alert the user to leave.
How do I turn off the Audible Exit Delay option?
Thanks!!
Old 09-22-15, 01:16 PM
Programming location 014: Turn OFF option 6.
Old 09-22-15, 04:59 PM
I did that setting...I think it must be unique to arming with the Keyfob, which is what I mainly do...So I think I need to find a keyfob related setting.
Thank you!!
Old 09-22-15, 05:03 PM
There is some sort of SIA False Alarm settings that speak to the Key Fob and Audible Exit beeps...
"System Times and Audible Exit beeps can be disabled when using the Key fob to arm away the system"
It says this:
Exit Time and Progress Annunciation/Disable or Remote Arming [005] and [014] bit 6
However I'm not sure how to program that....Section [005] is expecting times for the delay...I'm not sure how to set bit 6 on that.....
Old 09-22-15, 07:20 PM
No, section 5 is for time delays and the like.
I don't think you _can_ turn the audible off when arming with a keyfob. Just as with automatic timer arming, the feature exists to prevent the system being armed without those inside the perimeter knowing that the arming is taking place.
