Replacing system smoke detectors.
Old 10-03-15, 01:49 PM
My current alarm system is a Ademco Vista-20P. There are 6 - GE/ESL 449CST & 1- GE/ESL 449CSTE (located at the end) smokes. I need to replace the GE/ESL 449CSTE since it has failed and I want to replace it with a different model. I have researched and found the following two replacements:
1. System Sensor 4WTA-B & EOL Relay A77-716B
2. ESL 541NCSXTE
Is it ok to have two different brands of detectors in the same loop? Does anyone have a recommendation of another brand and model of smokes that would be better than I have found?
Thanks
Old 10-04-15, 04:09 AM
Since 4-wire smokes are just contact closure devices, mixing brand/model on the same loop is perfectly fine. You can even mix in heat detectors, in such a circuit.
