Reset Fire On NX8 and Hills Touchpad
Old 10-09-15, 04:34 PM
Hi
At a loss.
4 wire (in a string of 3) smoke detectors (ESL449C). After a smokey BBQ, number 2 detector has set the alarm.
Ho do I now reset the smoke detector. Cancelled the alarm OK, but hen I navigate to the alarmed circuit (Area 1), it displays the alarmed smoke detector however pressing the acknowledge button doesnt seem to affect a change.
Is there a setting I was meant to program in on initial deployment?
Cheers
Andrew
Old 10-09-15, 05:03 PM
Received 327 Votes on 306 Posts
You need to reset the smoke detectors.
Old 10-09-15, 06:13 PM
Thanks PJmax - unfortunately Im using a Touchnav which uses icons instead of a keypad - so there isnt any way of using this option from what I can see. I cant seem to find a Touchnav instruction manual anywhere to give further guidance.
Old 10-09-15, 06:48 PM
In case anyone else wastes as much time as I looking for the solution - there is in fact a reset smoke option under the 'Testing' menu.
Last place Id have ever thought to look!
Solved!
Old 10-09-15, 07:37 PM
There ya go. Thanks for the update.
