Vista 20P won't go into programming mode
Old 10-23-15, 10:51 AM
Hi,
Been trying for hours. I can't get my Vista 20P and 6150RF to go into programming mode.
I try using 4112 then 800 and it then beeps but it never goes into programming mode.
It does say FC (failed comm) - I can't even clear this errror without being able to get into programming mode.
What am I doing wrong?
Old 10-23-15, 04:09 PM
Received 25 Votes on 24 Posts
That means that either the installer code has been changed from the default, or programming was exited with something other than *99.
Disconnect the battery and AC power. (No, you will not lose programming)
Reconnect the AC power
Within 50 seconds press * + # at the same time. This should jump you into programming. Press #20 to display the current installer code (one digit at a time, ignore leading zeros; and write it down). Delete the phone numbers by entering *41* *42* & *94*.
Exit programming with *99.
Reconnect the battery.
Installer manual: http://www.nationwidesecuritycorp.co...all-Manual.pdf
