DSC PC1864 and PC5204 Gen Sys Trouble
Old 11-01-15, 06:33 AM
I have upgraded my hardwired alarm system with DSC PC1864 and PC5204. Ever since setting it up I have the Gen System Trouble code. I am using the PC5204 to expand my zones. I have logged into the PC1864 via the DLS and have configured the 8 zones. If I disconnect the PC5204 the fault goes away. I have configured the 4 zones on the PC5204 to use the existing window sensors no EOL resistor. I have jumped the Tamper contact. Power is 13.7v. The system sees the window zones connected to the PC5204 board. I have the exported XML attached if some can look over it and tell me if I am missing something.
Thanks,
File Type: txt
File Type: txt
Old 11-01-15, 07:05 AM
Did you run the module supervision command when you installed the expander board?
