Vista 20P - 6150 RF- number of zones
Old 11-03-15, 11:22 AM
I
Hello:
Vista 20P
Keypads - 6720, 6150RF, 5828 (wireless keypad)
transmitters - 15 total (5814, 5818, 5616, 5890, 5808 ) - door, IR, Smoke
I am working on updating some wireless transmitters to my Vista 20P that is about 10 years and had some questions..
1) 6150RF keypad as the wireless receiver - if zone 9 is first zone to program, I noticed it was not listed on my active zones. Is there a reason why zone 9 is not used? I read 16 maximum wireless devices with 6150RF and I have 10 - 25 programmed with other wireless devices. So is zone #9 available or zone 9 is reserved for 5828 wireless keypad or 6150RF or ??
2) Has anyone tried to add a IPDATEL CBAT -w/Internet & GSM? If so did you need to update the panel's PCB or PROM chip?
Thanks..
Irwin
Old 11-03-15, 06:52 PM
C
Received 35 Votes on 34 Posts
I can make an educated guess why the original installer left Zone 9 unused.
10 years ago, the Vista-20P was a new upgrade from all the previous Vista panels that started their expansion zones at Z10. Prior to then, Zone 9 had been reserved for Expansion Device Trouble. The installer probably skipped Zone 9 out of habit. It's available to add a wireless zone.
Unfortunately, I'll have to leave the IT question for another tech to answer.
Old 11-03-15, 08:00 PM
Received 92 Votes on 85 Posts
We recently had a person post about trying to use the IPDATEL device with a Vista panel. There were a _lot_ of issues with their documentation and tech support. He eventually got it working, but only after a _lot_ of back and forth.
http://www.doityourself.com/forum/el...disarming.html
Old 11-05-15, 10:32 AM
I
Thanks for the reply regarding IPDATEL add-on.
Do you know if GSMX-4G is a better choice?
Also, I think I need to update the PROM on my 10 year old Vista 20P, will this clear the current programmed panel?
Thanks..
Irwin
Old 11-05-15, 01:15 PM
As it's designed to directly interface with the Keypad bus of the Vista panels, it's going be easier to deal with. You do have to work through an alarmnet vendor, though...
