ADT Security System
Old 11-09-15, 08:46 AM
ADT Security System
I have an ADT system that is not connected to the ADT system. The system is Safewatch Pro 2000. It keeps beeping all the time. I found the panel box and I disconnected the battery...that did not work. I found where it was plugged in and unplugged it.That seemed to work for several hours and it has resumed a single beep about every 30 seconds. What do I do to stop this? Please it is driving me cracy.
Old 11-09-15, 09:24 AM
Welcome to the forums.
The Safewatch Pro 2000 should be a Vista-20SE panel.
Your manual can be found here.... Vista 20SE Installation Manual - Free Alarm Manuals
The first two screw terminals are AC power from the transformer to the board. Remove the wire from terminal one and the panel should be dead.
Name:  vista_20SE - Copy.jpg
Old 11-09-15, 10:14 AM
Is this the panel in the attic in a mental box...or the panel on the wall. Many Thanks
Old 11-09-15, 10:17 AM
Should be in a metal box.... where the battery was.
Old 11-09-15, 10:27 AM
If you have powered the system down, and are still hearing a chirp at about 30-60 sec intervals, then you are looking for a smoke alarm or CO detector with a low battery (typically NOT part of the security system...).
