Accessing a DSC Escort 5580 (phone access code unknown) ...
Old 11-17-15, 10:43 AM
The house I recently purchased has a DSC 5010 and Escort 5580 system. Non of the codes were provided by the seller nor was she able to remember them. Fortunately the 5010 installer code had not been changed so I was able to go into the programming and change the master code. Unfortunately the default phone access code [***] for the Escort 5580 was changed and I can’t seem to access it for programming. If I call it from my cell phone as explained in the manual, it will respond with [Hello] but that is as far as I can get with it without the phone access code. This leads me to a few questions.
Is there any way to access the Escort programming via the 5501Z keypad (not the phone)? From what I've read I don't see there is a procedure to do so. Any work around?
If I have to reset the system to default, will I loose all programming that has been entered to the Escort 5580?
How can I reset just Escort 5580 without affecting the DSC 5010 programming?
Old 11-17-15, 12:52 PM
Received 28 Votes on 27 Posts
*8 [installer code] 995
See PC 5010 installer manual section 5.32.2 (page 38)
Old 11-17-15, 01:29 PM
Very well.... by that reply I may assume that there is no work around the pass code and I must lose all programming that was previously setup on the Escort module. I was sure hoping not to have to reset it all over 3 characters. But I guess I could sit here and fish through over 1700 possible codes... lol - not going to happen. Suppose resetting it is just what I got to do.
Thank you again for your valued time!
Old 11-17-15, 01:37 PM
Sadly, yes, other than a default, there is no workaround to reset just the access code on the escort module. It's one of the few DSC modules that doesn't program from the system keypad.
