(DSC) Question about PGM programming
Old 11-24-15, 03:26 AM
Hi,
I would like to provide power (12vDC) to a GSM dialer through a supervised output from a DSC panel.
Because the GSM board needs too much power, I've bought a PC5204 module. This card has 4 PGM outputs.
The normal behaviour seems to be the PGM output is activated when the alarm is triggered.
Is there a way to instead have the PGM always activated (NC to ground) but still supervised (if the wires is cut an alert is triggered)?
The only way I can think of is to create a new dummy zone as a [26] 24-hrs Non-Alarm (Zone will not create an alarm) and use the PGM option "Zone Follower".
Questions:
1) A 24hrs-Non alarm zone is active or non-active all the time?
2) What PGM attribute [501] should I select? [3] ON/OFF??
This solutions doesn't seem very elegant but I cannot think of anything else.
Suggestions are very welcome
thanks a lto
Old 11-24-15, 02:14 PM
Received 25 Votes on 24 Posts
Looking at the instructions: http://cms.dsc.com/download.php?t=1&id=15120
Output 1 is a supervised output, so if you have it connected to a load with a 1K resistor to supervise, that circuit being cut would trigger a trouble.
I take it you are trying to supervise the power to your GSM communicator?
