VISTA 10SE Alarm
Old 12-05-15, 05:42 PM
VISTA 10SE Alarm
Hello,
I have a VISTA 10SE system that has not been used in 8 years. Would like to use the system for audible burglary protection.
I replaced the batteries in the sensors over all of the doors, replaced the 12 volt battery in the panel. When I power up the panel, the keypad (best I can tell is a 6128 that is direct wired to the panel) powers up with the red "armed" light and green light lit up but the screen is blank.
I have looked at other forums and have tried pushing the * and # keys at the same time but nothing happened. I also tried the 1 and 3 keys and the screen momentarily flashes "01"
I do not know the master code. Any suggestions. I'm not looking for a monitoring service just simply wanted something for localized audible alarm.
Any advice
Old 12-05-15, 05:53 PM
I may have an old pass code that the previous owner gave me. Is it possible that the system was powered down so long that is lost it's programming data?
Old 12-05-15, 07:42 PM
Press 1 & 3 then enter '3 then 1' for address 31 -- Sounds like it is currently addressed for 01.
That should allow you to use the keypad.
No programming is lost, only date/time.
Old 12-06-15, 06:39 PM
Thank you, I did that and now it reads d1 in the upper left corner, and Not Ready in the lower right hand corner
Old 12-06-15, 06:47 PM
Thank you so much,
I have it operational now. The old code worked great and the system is working great. I have replaced the battery in the panel but I still have an intermitting BAT
Old 12-07-15, 02:03 AM
Received 25 Votes on 24 Posts
If the BAT is accompanied by a zone number, you may have a transmitter with a bad battery, or at least a borderline one.
Old 12-07-15, 12:10 PM
No zone number. I saw an instruction somewhere that when the battery is changed there is a need to "code" -"off" twice. Tried that but did not change is. System works great though. Will have to do some research on how to bypass the alarm report since we are only using it as a localized alarm system.
Old 12-07-15, 12:31 PM
[Installer code] + 8 + 0
*41*
*42*
*94*
That will disable the communicator and clear the communication trouble.
Exit programming with *99
