DSC Keypad lost tamper widget
Old 12-06-15, 10:45 AM
Hi,
Hope someone can help me please.
I've been trying to install a DSC alarm and when I wired the keypad up to the alarm I get a keybus error. The wiring is correct I checked and double checked however I've noticed that the tamper rubber thing - sorry not sure of correct terminology is missing.
Firstly is this causing this error and secondly is there any way of replacing it without buying a brand new keypad in other words can I make one?
Many thanks in advance
Old 12-06-15, 01:19 PM
It's pretty much the same contact device used for membrane keypads.
Check with your local alarm dealer, that same piece is used on the door/window transmitters, and they often have a few floating around from replacing bad transmitters. Otherwise, a transmitter is much cheaper to buy than a keypad.
Old 12-06-15, 01:51 PM
Thanks and do you think that is what is casuing the keybus error?
Old 12-06-15, 06:11 PM
Assuming that you have the keybus wiring and connections correct, it seems likely.
