How to change master code with 6162 keypad
Old 12-08-15, 02:54 PM
T
Howdy, probably an extremely dumb question, but I can't seem to figure out how to change master code with 6162 keypad. Master code + [8] + 02 + new user’s code + new user’s code wont work on the 6162. Can I change it under the settings screen where you can add users and what not? I have all the bugs worked out except for this. I even used the wrong package of resistors that took me a day to figure out why every zone had a fault! Good grief!
Old 12-08-15, 04:24 PM
Received 1,480 Votes on 1,368 Posts
What alarm panel is that keypad connected to ?
Old 12-08-15, 04:57 PM
T
Oops, sorry, a Vista 20p.
Old 12-09-15, 05:57 AM
Try doing Installer Code + 802 + the code you want to be Master Code.
Keep in mind the IC and MC can't be the same.
Old 12-09-15, 06:47 AM
T
Tried that too, didn't work.
Old 12-09-15, 07:45 AM
When you press IC + 800, do you see '20' or 'Installer Code 20' on the keypad display?
Old 12-09-15, 07:54 AM
T
Yessir, I can do everything it just wont let me change the master code. I was able to change the installer code with no problem. This newer pad seems to have quirks, supposed to be more user friendly but I am thinking not.
Old 12-09-15, 08:01 AM
What happens when you press IC + 802 + new 4-digit MC?
Are you hearing any beeps at the end of the sequence? Are you hearing beeps for every button pressed during the sequence? Are you pressing the buttons in fast succession with no long pauses in between buttons?
Old 12-09-15, 08:46 AM
T
When I try to enter the new MC, it doesn't give me the confirmation beep at the end. I don't recall if the keys beep when pressed, I think so. I have a second keypad, a 6152 I believe, I am gonna try to change it from that one and see what happens.
