Trying to figure out an RJ-31X phone jack
Old 01-13-16, 02:19 PM
I am trying to wire in a RJ-31X. It may not be able to work this way, but here is how I attempted to wire it up as a test.
- Wired one side of a 4-pin modular plug to a house phone, the other end was wired to the RJ-31X (Red and Green to the RJ-31X 1 and 8, respectively).
- Wired one side of a 4-pin modular plug directly to the wall outlet, the other end was wired to the RJ-31X (Red and Green to the RJ-31X 4 and 5, respectively).
* Tested the house phone that was connected to the 1 and 8 on the RJ-31X and dial tone was present.
* Plugged a secondary 4-pin modular plug into the modular plug on the RJ-31X and dial tone to the house phone disappeared. Tried several things, but could not get the dial tone to stay on the house side.
Does this unit not operate like this? Does it need to be connected directly to the Demarcation point? Im am just testing the unit, but it seems like it should work.
I appreciate any help, just trying to learn.
Old 01-13-16, 04:35 PM
Received 1,112 Votes on 1,032 Posts
An RJ-31X is a communications jack.
You connect the incoming phone line to terminals 4 and 5.
You connect the phone or the rest of the house to terminals 1 and 8.
If nothing is plugged into the jack the phone line is passed thru it to the phones. When you put a plug into it....... the incoming line is separated from the outgoing phone.
Some RJ-31X jacks do not use the shorting method. That means without a plug in place and wired...... nothing is passed thru.
When the alarm is in standby..... it's like the red and green jumpers are in place passing the line thru the alarm panel. When there is an alarm...... the dialer disconnects the phones from the phone line and just allows the panel to communicate. When the dialer is finished.... the lines are reconnected.
Old 01-13-16, 05:19 PM
Is it possible to connect an emergency pool phone to an RJ31X, when the phone is being fed only 2 wires (red and green)?
Old 01-13-16, 08:05 PM
T
Received 14 Votes on 13 Posts
Yes, but the remaining phones will not be disconnected; that is done by the alarm panel. I doubt your pool phone provides that feature.
Old 01-13-16, 11:43 PM
Why do you have an RJ-31X jack ? Do you have an alarm panel there ?
If not.... just connect the phone across the main phone lines.
