Adt dsc impassa chirping
Old 01-25-16, 07:56 PM
K
My unmonitored ADT alarm just started beeping 4 days ago and beeps incessantly at night. It says VIEW TROUBLE Alt. COMM. how can I reset or get rid of the beeping? I'm desperate! Please help!
Old 01-26-16, 02:20 AM
Received 89 Votes on 83 Posts
Installation manual: http://cms.dsc.com/download.php?t=1&id=17242
If you have a cellular communicator installed, many of the older models have 2-G models which are starting to be sun-set out by the cell providers. The only fix is to go into programming section 382 and turn off option 5 to disable the cell communicator, since DSC doesn't make a 3G or 4G replacement for this model.
Old 01-26-16, 08:23 AM
K
MrRonFL
Thank you! But i'm as dumb as a boot when it comes to this kind of stuff lol
Do I need a special code to access those functions? and Do i just punch it all in? Sorry to ask so many questions but i'm not too sharp with these kind of devices lol
Old 01-26-16, 08:49 AM
You need the installer code. If this was installed/configured by ADT, it is most likely the typical ADT installer code (which we can't post on this forum, or ADT fusses): https://www.google.com/search?q=adt+...oe=&gws_rd=ssl
The command is *8 [installer code]
382
press 5 to turn OFF option 5
press # until you exit programming.
That _should_ do the trick. You _might_ have to disconnect the communicator module from it's connection point.
Old 01-26-16, 08:57 AM
K
Will that clear the orange trouble light that's on the panel as well or just shut the alarm up?
Old 01-26-16, 11:33 AM
That _should_ get rid of the trouble light, assuming that the failed 2G communicator is the only problem. Normally, pressing the # key will silence the trouble warning for 24 hours.
Old 01-26-16, 01:42 PM
K
well I also have a smoke detector that sounds off and says low battery lol so I guess I should address that as well. Thank you so much for your help. When I get home later today, I will hopefully silence my alarm lol Thank you!!!!
