Are there newer DSC wired lcd keypads compatible with the 5500
Old 01-30-16, 07:21 AM
I just got my system up and running except the keypad that is just outside the garage. The pushbuttons do not operate. Will a newer wired DSC control that will monitor up to 32 zones work instead. I cannot find a 5500Z keypad anywhere.
Thanks, Mark
Old 01-30-16, 09:21 PM
Received 97 Votes on 90 Posts
Most of the system models that used the PC5500z keypad are compatible with the newer PK5500 keypad. What is the model of your the system the keypad is attached to? Bear in mind, that the keypad descriptors are part of the keypad, so you would need installer code access to swap the keypad out.
