Adding a door alarm to unmonitored ADT system
Old 02-13-16, 10:14 AM
D
I have an unmonitored Safewatch QuickConnect Plus system by ADT, which is essentially a Honeywell Lynx Plus alarm system. I have door alarms set up on 2 of the 3 doors, and I'd like to add one on the remaining door. How can I do this?Name:  61886d1453397308-honeywell-adt-alarm-no-longer-works-screenshot_2016-01-21-11-27-16.jpg
Old 02-13-16, 10:57 AM
T
Make sure you can get into programming, buy a sensor, program it in.
Old 02-13-16, 11:30 AM
Received 128 Votes on 119 Posts
First, you will need the installer code. Websearch using the phrase "ADT installer code" (they fuss if we post the code on this site). The typical code is commonly known, and easy to find.
Then you will need an installation manual: http://helpdesk.nex-tech.com/files/i...rogramming.pdf
You will need to know your existing zone numbers, so you know what zones are available.
Read over the programming steps (*56 programming) and let us know what part of the programming sequence you have trouble following.
Old 02-13-16, 03:03 PM
D
Thanks for the reply. How do you sync the door alarm to the keypad? Currently if the front door opens (zone 2) it says "Beep beep front door."
What alarm should i be looking for on Amazon?
I had bought a different door alarm a few years ago but it didn't make a gentle beep beep sound. It was scretchy wailing siren sound. I just want a simple chime if my toddler tries to open the garage door.
Old 02-13-16, 03:27 PM
Received 1,506 Votes on 1,393 Posts
Make sure you can get into programming before ordering. The module is programmed once in panel programming mode.
Honeywell 5811 Honeywell 5811 Thin Door/Window Contact Transmitter
Old 02-14-16, 06:49 AM
The sound is generated by the keypad/control. What you need is a compatible door contact transmitter.
Honeywell 5800 series devices are what you need.
