do you recognize this fire/smoke detector?
Old 03-09-16, 04:00 PM
I need to replace very old fire/smoke detectors but can't ID what I have. Can anyone recommend what I should get to replace these?
Pictures attached
Old 03-09-16, 05:39 PM
Received 24 Votes on 20 Posts
Any Smoke should work if the plugs are the same.
Some even come with an adapter.
You Did try and Google the make and model # right?
Old 03-09-16, 09:19 PM
Received 215 Votes on 204 Posts
Those are some old clunkers and do need to be replaced.
You can replace them with System Sensor 4 wire smoke detectors.
This is just one..... there are more..... System Sensor Fire Alarm Products
Be sure to ID the wiring on your smoke detectors before disconnecting them. There isn't always a standard wire color code used.
Old 03-20-16, 10:48 AM
Just received the new 4 wire smoke detectors and am installing them now. The old smokes have plugs, the new has screw terminals. The old smoke has, two red (+power), two black (gnd), two purple and two white w/ purple stripe wires. The new smoke has screw terminals +, -, N.O. and C.
QUESTION: does it matter if the purple or white w/ purple stripe are connected to the N.O. or C terminals or vice versa? Red and black are obvious.
Old 03-20-16, 11:29 AM
There is no polarity on the N.O. / C terminals.
Old 03-20-16, 11:34 AM
all set works like a charm!
