Alarm beam detector does not work
Old 03-26-16, 03:40 AM
N
Hi,
I purchased this ALARM BEAM DETECTOR below from eBay but does not work
when 12v powers both Tra.& Rec.
I powered another make (Zin Zan) 8 years ago & still works OK today.
In the attached image 5, I connected a 12v 2A adaptor & a piezo buzzer but it does not work. The buzzer when powered separately works OK.
Image 9 shows my test rig for Transmitter & Receiver.
Can anybody point out what connections I should make in image 8 to make the buzzer work when the beam is cut.
Alarm Dual Beam Photoelectric Infrared Detector 100M Home & Garden Security LN | eBay
Old 03-26-16, 05:14 AM
Received 129 Votes on 120 Posts
Connect the + power lead on your buzzer to terminal 5. Connect the - power lead from the buzzer to terminal 2 with the incoming - power supply lead. Connect a jumper from the + power lead on terminal 1 to terminal 3.
Old 03-26-16, 09:16 PM
T
Where was that made?
That '1' is backwards and the numerals are reversed.
Good luck with that -- Cannot say I would trust it.
Old 03-27-16, 12:34 AM
Received 1,512 Votes on 1,398 Posts
For what it is..... or it claims...... it's only $20 US. Pretty inexpensive. Based on the price of beam detectors I use..... the quality is probably marginal and the reliability may be questionable.
The company is AILIF security technology from Guangdong, China
