Need some help programming caddx network nx-6
Old 05-24-16, 10:15 PM
System Board Replacement
If I did replace the system board, with for example NX-8 or NX- 6V2 would I be able to use all my wireless sensors, keypads, two wired motion detectors along with my wireless NX-408.
Old 05-25-16, 04:49 AM
Received 32 Votes on 31 Posts
Yes, but you would be programming everything from scratch.
  #43
Old 05-25-16, 07:16 PM
Nx-591e-gsm utc
MrRonfl
what is your opinion of the NX-591E-GSM UTC thinking of going this route instead of telephone line. I've read that there is a NX-592 but unsure if it is compatible with my system. I'm not comfortable replacing the system board right now.
I have gotten a better perspective on programming the system with your help, but not there yet.
  #44
Old 05-25-16, 07:57 PM
The cellular units work very well, but you have to go through a dealer to have them work. IT's not a matter of popping a sim card into the units.
NX modules are generally backward compatible. The difference between a NX-591 and 592 it that they go through two different service dealers.
  #45
Old 05-26-16, 09:44 AM
Gsm
You mentioned that I would have to go thru a dealer to have it work.
Does that mean I would have to purchase new? There are a few 591 on ebay.
  #46
Old 05-26-16, 11:14 AM
No, it just takes a Cellemetry or Alarm.com dealer to activate the unit. Used ones can be reset to factory default.
  #47
Old 05-26-16, 03:16 PM
Thank You!
I think I will look for a used 592, believe it's 4g where the 591 is 3g
  #48
Old 05-26-16, 09:40 PM
591 is UTC/GE's cellular radio.....very limited options with this guy...basically it will page/text or email you system events...
592 is the Alarm.Com radio....
go with the 592....
both require you to activate them through a dealer...
  #49
Old 05-28-16, 06:19 PM
Battery Backup
Good News, We lost power to our home today. Battery backup does work.
Not sure why when I unplugged the power from the ac, battery backup did not work, but the power ac was plugged in when we lost power, battery backup worked as intended.
  #50
Old 06-11-16, 08:36 PM
Zone Descriptions
When I installed the new keypad the zone descriptions did not copy over.
Example: zone 16 - Kitchen - existing keypad
zone 16 zone 16 - new keypad
  #51
Old 06-11-16, 08:44 PM
Are both keypads the exact same model number? If one of them is a NX-148 and the other is a NX-148E, the data may not transfer properly. You may have to manually program in the descriptors to the new keypad.
There are also settings that could have been set that make the transfer not work.
  #52
Old 06-11-16, 11:52 PM
Keypads are the same. I could not find how to manually program the descriptors in the new keypad, please direct me.
Thanks
  #53
Old 06-12-16, 10:39 AM
Installer manual: http://www.homecontrols.com/GENX148E_Installation.pdf
Page 5 has the shortcuts for the letters and pre defined words
Page 9 has the programming instructions for the custom messages.
If you did not enter the message programming on the existing keypad and make a change, then the messages would not have automatically transferred to the new one, as previously observed.
  #54
Old 06-12-16, 10:08 PM
What is the simplest change that I can do so I don't mess something else up.
  #55
Old 06-13-16, 03:23 AM
Add a space to the end of a word.
  #56
Old 06-18-16, 06:42 AM
