NX 6 Program Issue
Old 06-19-16, 01:55 PM
NX 6 Program Issue
I had to install a new control board and power supply for my alarm. I have programmed the units zones. The unit continues to beep nonstop.
Help?
Old 06-20-16, 03:11 AM
Received 38 Votes on 37 Posts
Enter your code to stop the trouble beeps. Then check the trouble codes.
Old 06-20-16, 01:46 PM
Thanks for the reply. I have done that and it does not help.
Any other suggestions?
Old 06-20-16, 05:36 PM
What is showing on the keypad while it is beeping?
Old 06-20-16, 08:44 PM
The "Ready", "Power" and "Service" lights are illuminated. They are constant,not blinking.
Old 06-21-16, 06:43 PM
If you press *2, what code(s) are displayed?
Also, are you entering your master user code, or the installer code? The latter will not stop the beeping.
Old 06-21-16, 07:00 PM
The zone 1 light illuminates. The service light starts to blink.
The code I am using is 9713.
Old 06-21-16, 09:04 PM
That's why it won't shut up. That's the _installer_ code. You have to enter a _user_ code (the default is 1234).
That trouble code needs further follow up. See the chart on page 15 of the user manual: https://paladinsecurity.com/download...anuals/NX8.pdf
Old 06-22-16, 09:37 PM
Thanks>
I will check that tomorrow.
Old 06-24-16, 10:34 AM
Thanks. That did it.
How do I reset the factory code?
Old 06-24-16, 10:51 AM
Page 10 in the user manual:
*5 [master code]
enter 2 digit user code # to change (the master code is user 01)
Enter new code
press #
