Doorbell Transformer for Vivint Home Security
Old 06-26-16, 03:09 PM
I'm having to change my old doorbell transformer due Vivint home security doorbell camera burning it out. I bought a transformer that will convert it to either 8-16-24 vac. Vivint wants 24 so I hooked my two wires to the outside posts which appear to be the 24 vac. I turned my power back on and I had no power and the transformer seemed to be hot. Any tips or ideas?
Old 06-26-16, 03:21 PM
Received 370 Votes on 347 Posts
Welcome to the forums.
Those cameras use very little power. The transformer shouldn't even get warm.
I doubt the camera burned out the transformer. Sounds more like a short. Possibly at the back of the camera where it's attached.
Old 06-26-16, 05:02 PM
I was looking into this further but could not find what the current requirements are for that doorbell camera. I would think a 24v 10va transformer would be plenty.
Apparently it's a guarded Vivint secret.
Old 06-26-16, 07:05 PM
Received 30 Votes on 29 Posts
Simple test: Check for voltage with transformer disconnected from the field wiring. If voltage is correct, connect field wiring. If voltage drops to zero, then the field wiring, or the end device has a dead short. Check voltage at device end. If voltage is correct at wires at device end, but drops out when connected, then you have a failed device.
Wire from load to source. Test from source to load.
