IP camera wiring
Old 06-30-16, 01:50 PM
X
Post IP camera wiring
I am considering installing the IP (POE) cameras.
I am planning on getting my house exterior painted.
Should I run all the ethernet wires, tack them down under the eaves BEFORE the painting starts, or wait till the painting is done, THEN run the wires ?
My thoughts were to put the wires down first before the painting so the wires will become the same color as the eaves, and more concealed..but please let me know if the other way would be better for whatever reasons.
thanks !!
Old 06-30-16, 02:49 PM
C
Received 2 Votes on 2 Posts
I'd probably wait until after the painting. With the wires in place there may be a bit of siding under them that doesn't get painted and then if you find out you have to move one or change one you've got a strip of unpainted siding showing. You want the siding to be smooth and nicely finished.
It will be easy enough to paint the cables afterward if you decide it's needed. Best would be to use cable that blends in a bit if possible and then not paint it.
But not a huge deal either way.
Old 06-30-16, 03:17 PM
X
Good point. I didn't think of the fact that if wires get moved, they will be unpainted areas under the eaves. Thanks !!
Old 06-30-16, 03:31 PM
Norm201's Avatar
Received 372 Votes on 337 Posts
After painting. I ran my wires under the vinyl siding where they overlap and between corner molding.
Old 06-30-16, 09:55 PM
Received 1,601 Votes on 1,475 Posts
Standard Cat5E cable is not designed for outside installation. The sun will cause the insulation to crack. I use gel filled cable when it needs to be exposed to the elements.
For most of my residential camera installations I run the cable either under vinyl siding or I drill up thru the soffit into the attic. If there is no attic I fish thru the soffit.
Old 07-01-16, 09:57 AM
X
any possibility to post a picture so I have a better idea how an ideal installation ought to look like ?
I was under the impression that i would simply tack the wires under the eaves and find a common place for all 8 wires (I'll have 8 cameras) to enter the house, most likely the garage.
Old 07-01-16, 11:10 AM
Can you post a pic or two of your house in the area you want to put the cameras.
http://www.doityourself.com/forum/el...-pictures.html
There is no "ideal" installation. Actually an ideal installation is where the cameras are minimally visible.
Good location. Effective, easy to get to from attic and out of sight.
Old 07-01-16, 03:07 PM
Norm201's Avatar
Using Pete's picture above that is exactly how I wired mine. Only I'm using wireless and only needed to run the power line.
Old 07-02-16, 09:35 PM
Received 139 Votes on 128 Posts
You can get outdoor rated CAT-5/6 wire. It's a bit more expensive, but it's still better to mount it so that it's out of the weather/sun and not in sight. Tucking it into the soffit J-channel is probably the smart course of action.
