Ademco 4110 DL
Old 07-14-16, 05:12 AM
Ademco 4110 DL
Hi
is ademco 6150 keypad compatible with 4110 dl panel?
Thanks
Old 07-14-16, 07:13 AM
Received 13 Votes on 13 Posts
Yes, it is. Ademco has the industry's best record for making new peripherals back-compatible with older panels.
You'll need to be sure the keypad address is set at 31 in Keypad Local Programming.
Old 07-14-16, 07:29 AM
Yes I knew about addressable keypad should be set to 31, the manual only mentioned 6137 , and 6128 as far as I remember , nothing about 6150, I thought 6150 will work just I wanted to make sure . Thanks a lot
Old 07-14-16, 05:11 PM
Received 32 Votes on 31 Posts
6150 - Yes, backward compatible to this model alarm control.
6160 - NO, NOT compatible with this alarm control model.
