Safewatch 3000- stuck in programming mode
Old 07-27-16, 08:24 PM
Hello,
We recently purchased a new home with a Safewatch 3000 system. I was trying to add a new user code (it's still set for the factory 1234), and I think I have locked myself into the programming mode. I have tried keying in the master code, *99, and random combinations of keys. Nothing seems to work, and now the screen is simply blank with "no AC" on the display. I cannot find a place where anything is plugged into a wall socket, but I have found the locked box and the transmitting device. There is no key anywhere in the closet. Can anybody provide me with additional suggestions?
Thanks!
Old 07-28-16, 02:39 AM
Received 32 Votes on 31 Posts
Eventually the programming mode will time out and the system will go back to normal. I suspect that you may have inadvertently entered one of the menu mode programming areas without having a 6160 keypad to see the prompts.
Old 07-28-16, 07:18 AM
Thank you for your help MrRonFL!
About how long can I before the programming mode times out? I finished working on the system about 11:00 last night, and it was still in programming mode this morning at 7:00.
You are correct, I am not able to see the prompts.
Old 07-28-16, 01:54 PM
You could also just power cycle the system by removing a lead to the battery and unplugging the wall transformer and it should power back up out of programming mode.
Old 07-28-16, 04:36 PM
Normally, without any keypress activity, the program mode will time out in about 5 minutes. Hard to tell exactly what you got into that locked it so thoroughly. Power cycle the system, as described above.
Old 07-28-16, 05:05 PM
Can do. My system did not come with a key, so I have purchased one from Ebay. It will be a few days before it arrives and I can perform the recommended actions, but I will update as soon as I am able.
Old 08-02-16, 09:00 PM
The key and power cycle worked, and now I am able to use the system regularly. I am however receiving a "alarm 108" that is sometimes also displayed simply as 108. it does not seem to affect the system but never displayed before I got stuck in programming mode.
Old 08-03-16, 02:54 AM
Installer manual: http://www.nationwidesecuritycorp.co...all-Manual.pdf
In your fumbling around, you must have accidentally created a "zone" numbered between 17 & 24. The trouble "108" is telling you that there is a missing hardwired zone expander to support that zone. The only way to fix this is to buy or borrow a 2-line alpha keypad (6160 or equivalent) so that you can get into zone programming (*56) and delete the false zone you accidentally created.
Old 08-03-16, 07:42 AM
Get into installer programming, then enter the following EXACTLY...
*58(screen will show 01)
17 * 00 * 1(screen will show18)
* 00 * 1(screen will show 19)
* 00 * 1(screen will show 20)
* 00 * 1(screen will show 21)
* 00 * 1(screen will show 22)
* 00 * 1(screen will show 23)
* 00 * 1(screen will show 24)
* 00 * 1(screen will show 25)
00 * * *99 will exit you from programming
Do this at your own risk, I've programmed thousands of vista plus series panels( which is really what you have- it's just ADT's version) this way over my career. That being said, I take no responsibility if something happens, you missing a step & getting lost in programming, deleting something by mistake, panel melting down, or the end of the world(😉🙂lol)
Old 08-04-16, 04:56 PM
Good news, the world did not end! I also didn't get stuck in programming mode AND I was able to delete the unassigned/ unintentional zone.
I have a follow-up question. How do I remove the 1234 preset code? That was my original intention for getting into programming mode in the first place. I see how to assign each user a code, but I assume that 1234 is not a user code. I don't know how to describe it (master code maybe?) and therefore finding instructions to change it has been difficult.
Old 08-04-16, 06:17 PM
[installer code] + 8 +02 + [new master code]
or you can do
[Master code] + 8 + 02 + [new master code] + [new master code again]
It's actually in the _User_ manual, so they didn't duplicate the information in the installation manual.
Old 08-05-16, 08:15 AM
Everything is working great. Thanks to everybody who responded to help me; I am thankful for your knowledge and support!
Old 08-05-16, 08:58 AM
Always glad to help. Good luck
Old 09-03-16, 12:50 PM
My system has been working well, but I am now receiving an error 94. I looked it up, and the manual indicates that this is an error with the telephone line, but this system is not monitored. Does anybody have a suggestion for how to remove this error code?
Old 09-03-16, 04:24 PM
Go into programming like before, enter *94*, *, *99
Old 09-03-16, 06:59 PM
Super easy fix. Thanks for your help!
