Home Alarm Question
Old 08-31-16, 07:46 AM
K
Home Alarm Question
I have a wired home security system that's been installed and working fine for over ten years. I would like to add a second magnetic contact to an existing window (that already has a contact). I've been reading about this and it seems the easiest way would be to wire the second contact in series. My question is how do I wire it? I have 2 wires (black and yellow) connected on the first contact on the window. Also does this setup require adding a resistor?
Thanks for the help
Old 08-31-16, 11:00 AM
Received 2,946 Votes on 2,659 Posts
Welcome to the forums.
The addition of a resistor is not required.
If there is a resistor present at the original switch then it needs to be maintained.
The switches just form a series loop. The color of the wire is not important.
Both switches must be closed for the circuit to be normal.
Old 09-01-16, 07:12 AM
K
Thanks PJmax worked perfectly.
