Vista 20p sounder output question
Old 09-04-16, 04:15 PM
Strange request...is there a way to make the sounder output (terminal 3) steady for fire alarms instead of pulsed? I am using relays to different devices and need continuous for fire and burg. Thanks
Old 09-05-16, 07:23 PM
Received 38 Votes on 37 Posts
That's a hardwired function on V20p panels. To get a steady output, you would need to use the output connector, and program an output to turn on steady in alarm.
Old 09-05-16, 07:30 PM
Thank you. What do you mean by output connector? The auxiliary power output?
Old 09-06-16, 03:08 AM
The specific name is the onboard trigger connectors. See page 2-11 in the installation manual: http://www.nationwidesecuritycorp.co...all-Manual.pdf
Old 09-06-16, 08:52 AM
Received 7 Votes on 6 Posts
Also, take note of the current limitations on these outputs.
Old 09-07-16, 03:19 AM
If the primary goal is triggering relays; the outputs are definitely the way to go, that is going to be a low current application.
