How do I remove zone 6 hard wired into my nx8v2/148E-RF
Old 09-12-16, 06:03 AM
B
How do I remove zone 6 that is wired? Want to replace with 4 wireless sensors 60-362, 4 Windows in that bedroom/zone. nx8v2/148E-RF
How do I program to remove hard wired zone 6?
How do I program new wireless sensors?
Old 09-13-16, 02:40 AM
Received 133 Votes on 123 Posts
The foolproof way is to disconnect the wires on that zone input and replace them with a 3.3k resistor (orange orange red). No programming necessary.
Keypad manual: Installer manual: https://www.surveillance-video.com/m...stallation.pdf
Adding transmitters is on page 6. You just need to know what zone numbers you have available. Each transmitter needs it's own zone.
Old 09-13-16, 06:13 AM
B
Can you go through a step by step for wireless zone 9 and 13? Thank you in advance.
Old 09-13-16, 07:40 PM
Actually, the example in the installation manual is for programming a transmitter to zone 9, after that, you are just following the same steps with a different zone number.
Old 09-14-16, 05:49 AM
B
The link below is not bringing me to an instruction manual. Please verify link. Thanks.
Old 09-14-16, 03:32 PM
I copied it from your previous question, and assumed that you had already downloaded the manual:
Old 09-16-16, 12:40 PM
B
It's not working for me. Go through steps, then open shop door with new sensor, no response. What am I missing? Thanks
Old 09-16-16, 01:11 PM
Assuming that you have never had a device on zone 9 and the keypad is RF keypad is set as keypad 1:
Step by step:
*8 installer code
192#
400#
9* (if you hear 3 beeps, then you already have something enrolled on zone 9 and need to select a different zone number)
Trip the transmitter by opening the battery cover. You should hear a "Ding-Dong" from the keypad.
You can use the [exit] key to exit programming.
Unless someone has altered zone programming, zone 9 is already enabled as an instant zone for partition 1.
Old 09-16-16, 01:42 PM
B
Zone not tripping at end of sequence. Trying to secure my house in flooded area, can't live there.
Old 09-16-16, 02:01 PM
B
Got it! Thank you so much. You have always been a reliable source of help and information. Thanks!
Old 11-28-16, 10:41 AM
B
Adding wireless contacts
Mr. Ron,
How many zones do I have on 192#,400#
I was able to put wireless contact on 14* and 15*, but anything above 15 beeps 3 times. I have 7 more wireless contacts I want to program. Thanks
Step by step:
*8 installer code
192#
400#
Old 11-28-16, 02:44 PM
A NX-8 is good for up to 48 zones. Double check your system board. Could you possibly have a NX-6? Those max out at 16 zones.
Old 11-28-16, 05:15 PM
B
Wireless contacts
Mr. Ron,
I was able to program them again beginning at number 20. So now I have wireless receivers at number 9,10,11,12,13,14,15,20,21,22,23,24,25,26. How do I program them to read out location, like 9 front window, 10 bedroom window, etc.? Thanks for your help.
Ron
Old 11-29-16, 02:29 AM
It sounds like you may have had devices, or failed programming attempts in those slots. If you are sure there's not actually a device on those zone slots, delete them. (installation manual page 8).
ftp://rrcs-70-60-240-226.midsouth.bi...%20Rev%20B.pdf
The instructions for programming zone descriptions are on page 11.
Old 12-01-16, 07:44 AM
B
Naming a zone
Mr. Ron, can you go through the step by step to naming a wireless contact? Example name zone 10 side window. My master code is 7878. Thanks for walking me through the steps for programming the wireless contacts.
Old 12-01-16, 02:56 PM
*92 [installer code]
At the prompt for message number, enter the zone number + #
Use table 10 from the manual to navigate the characters
  • * saves the character/word and moves the cursor to the right.
  • [CANCEL] moves the cursor to the left.
  • The up and down arrow keys next to the display scrolls up and down through the letters, numbers and symbols.
  • [STAY] Inserts a blank space.
  • [CHIME] Deletes characters
  • [EXIT] accesses the library of pre-generated words and phrases
  • [BYPASS] Makes the character/word flash
  • # Exits programming that message
