PC1832 Stay & Away buttons keys.
Old 09-13-16, 01:45 PM
Question PC1832 Stay & Away buttons keys.
Hi!
I've reprogrammed my DSC PC1832 and everything works great but the Stay and Away buttons. When I press one of them for 2 seconds, there is only one beep and everything disappear on the screen. Nothing more happens.
Do I have to program them to activate? I want to use them so the activate the alarm right away.
Thanks!
Old 09-13-16, 07:38 PM
Received 27 Votes on 26 Posts
Do you have option 4 in programming location 015 turned on?
It doesn't hurt to verify that the function keys are indeed mapped to be the arming functions as well.
Old 09-14-16, 05:29 AM
wow, works man! Turned that option ON and now it works like it should! THank you so much!!!!
Old 09-14-16, 10:19 AM
Still having a little issue, when I activate the Stay key, I get a door icon with a X on it. And the alarm doesn't start when I open a door... do you know why? THanks!
Old 09-14-16, 03:12 PM
It means that you have a door or window zone that isn't properly closing. From the sounds of it, it's your entry/exit zone. Remember, the little row of numbers at the top of the display shows what zone is open if you have a 5501 model keypad. For a 5500 keypad, you use the arrow keys to scroll the display.
Old 09-15-16, 05:02 AM
It's not that a door is opened, cause if I open a door, I just simply can't arm the system. Now it's arming but shows a door with an X on it and if I open the front door, the alarm doesn't start...
Old 09-15-16, 02:23 PM
User Manual: http://cms.dsc.com/download2.php?t=1&id=24147
That's the bypass symbol. If you arm the system without opening and closing an entry/exit zone, or arm in stay mode, then all interior stay/away zones will bypass automatically. Even if you don't have any zones programmed as such, the symbol will still appear. It's not a bug, it's a feature...
Old 09-16-16, 05:47 AM
Ok, why then when armed, nothing happens if I open a door?
Old 09-16-16, 11:45 AM
What zone is that door on, and what zone type is it programmed as?
Does that door normally show an open and closing indication while disarmed? (Does it chime?)
