PC1832 calling cell phone
Old 09-14-16, 05:47 AM
I'm trying to get my PC1832 to call my cell phone... but it doesn't when I make the test *6 [master code] 4.
Here is the programming I used:
*8[installer code] 301 [phone number] #
320 and entered 11 sixteen time(11 11 11 11 11...)
350 and entered 05 05
311 and entered 1 2 3 4
Someone knows why it's not calling on the test?
Thank you so much!
Old 09-14-16, 03:30 PM
Have you programmed a code into system test segment of programming location 348? It just needs to be a non-zero value. I usually use 11.
Every zone and system action that will activate the dialer needs to have a code programmed.
Old 09-15-16, 05:16 AM
I've just added the 11 into 348 and redone the test, but still no call...
Old 09-15-16, 03:09 PM
What were the keystrokes you used to enter the code into the system test segment of programming location 348?
Old 09-16-16, 05:52 AM
*8 [installer code] 348 11 ##
Old 09-16-16, 11:59 AM
Thought so...
The system test report code is segment 5 of programming location 348.
You put the code into segment 1 (Walk test End)
To step to a lower segment without entering data in one of the preceding ones, you press any one of the emergency keys on a 5501 or LED model keypad.
The correct keystrokes would be:
(you start in the first digit of the first segment)
[E-Key] [E-Key] (it will double beep when you step to another segment)
[E-Key] [E-Key]
[E-Key] [E-Key]
[E-Key] [E-Key]
11 ##
Installer manual: http://cms.dsc.com/download.php?t=1&id=17007
