Remote water and freeze alarm - any recommendations?
Old 09-14-16, 03:45 PM
We own two homes and want to be able to get a warning if the temp drops or if there is water detected in the home that is vacant.
I've poked around online some but wanted to get recommendations from folks that have installed and lived with one for a while.
My thought is that the device will connect to our house wifi and be able to transmit an alert to our smartphones if the temp drops below a certain number or if water is detected.
Ay experience with these devices?
Thanks!
Old 09-14-16, 05:02 PM
Received 25 Votes on 24 Posts
It's a newish product, but there are numerous variant on the concept:
Smart Water Leak Detector | Honeywell Lyric
Old 09-15-16, 11:55 AM
Thanks, i'll check it out. I'd be interested in feedback from anyone that has used one of these devices.
Old 09-27-16, 06:35 PM
If you already have an alarm system any a/d converter with a temperature and float sensor with outputs will work. I don't have a source but making one from OTC stuff should be pretty easy.
Come to think about it, if there is a sump a float with a switch will wire directly into an alarm panel, and there are cheap digital thermometers you could use like maybe
Auber Instruments
Digital EGT Thermometer/Pyrometer with Analog Output
