Safewatch pro 3000 - Armed
Old 10-05-16, 10:59 AM
I rent a house that has an ADT alarm installed. I don't know any codes to use it, nor does owner. He purchased the home a month before I moved in. I've been here since July and would like to use it without monitoring. I tried to get the installer code from it as it would only chime at that point when door and Windows opened. I've somehow managed to arm the system and don't know what to do from here. I quickly unplugged the power cord as well as the backup battery. Can anyone help with this? I don't know what to do.
Old 10-05-16, 02:26 PM
Received 25 Votes on 24 Posts
First, unplug the phoneline. Within 50 seconds of restoring AC power, press * + # at the same time. It should jump into programming. Press #20 and it will read back the installer code, one digit at a time (ignore leading zeros).
Exit programming with *99. The system should be disarmed.
You can then set a new master user code by pressing:
[installer code] + 8 + 02 + [new master code]
Test the code by turning on and off the chime feature.
Installer manual: http://site.aesecurity.com/Manuals/v...stallation.pdf
