Disable green flashing light Ranger 8600 E
Have a Caddx Ranger 8600 E alarm system and I have a green flashing light (line fault) on the keypad. I am not connected to a telephone line and want to disable the flashing light and use as a stand alone system.
Installer manual: http://www.ackermansecurity.com/uplo...anger_8600.pdf
The old Ranger panels are _not_ DIY friendly. If you know the installer code, it can be programmed from the system keypad To change the programming settings without knowing the installer code requires either the 8050 programmer, or a 9050/9060 LCD keypad.
To disable the communicator, the setting in programming location 52 needs to be changed to "0".
