Ptz camera acts up after entering night mode
I tried taking off 1 black and 1 red lead but nothing changed. I am stumped as to what the problem might be with this camera. I am not sure even how I could disassemble it to see where the wires actually go but even if I could I have no idea what the various boards do in the camera anyways.
I posted a picture of the camera but it has no name on it.
Without a brand and model; it's kind of a guessing game. Anytime someone starts cutting into wiring without documentation they are rolling the dice.
Typically, a PTZ camera is going to have 6 wires and possibly an earth ground:
https://www.lorextechnology.com/imag..._PTZ_setup.jpg
When it switches to night mode it turns on the infra red LED's. Those LED's draw more power than the camera itself. Possibly you are having a voltage drop problem.
Thanks. Every camera I have bought has 7 wires. Video plug, power plug and 3 wires more. Two of the 3 are for RS485 and I always have a left over wire that I have no idea what it is for.
I always assumed it was to ground to the box for an earth ground. I never hook it up to see when I install the camera.
The colors vary according to the cameras. Sometimes those 3 colors are the same, green white, and yellow. But the green and white are not always the control wires. Sometimes it is the green and yellow.
I tried connecting the yellow to the black ground wire but it made no difference.
As far as low voltage I am not sure as I did not meter it but the power is connected thru a Siamese cable. I am testing it at my house so I can hook it (the power plug) straight to the camera to lessen the chance. Is there a certain voltage that is considered low?
I have had some cameras that use 24 volt but I don't remember if this is one. If I hook 24 volt to a 12 volt camera won't that hurt it? It seems to work great before the night mode come on with the 12 volt power.
