No AC Safewatch pro 2000 or 3000
Old 12-28-16, 12:00 PM
Yesterday I went through the process to reset the installer and master passwords in my system (power down/power up)
All got reset fine but when I was reconnecting the battery it sparked. Now the panel displays No AC.
I checked and have 18V coming from the transformer to the panel.
Not sure what else to check.
I said Safewatch Pro 2000/3000 because the panel has a tag that indicates it is a 2000 (savs20adt-1) but the keypad says Safewatch pro 3000.
Old 12-28-16, 12:08 PM
Received 1,505 Votes on 1,393 Posts
Welcome to the forums.
So the panel is running on AC but says no AC ?
Old 12-28-16, 01:49 PM
That would seem to be the case. I have ~18 V AC on the panel but the keypad says No AC
Old 12-28-16, 03:02 PM
Received 128 Votes on 119 Posts
You may have connected the battery in reverse polarity. Power the system down, both battery and AC. Leave it off for few and reconnect it.
A Safewatch 2000 (Vista 20se), or a Safewatch 3000 (Vista 20p); has a battery fuse near the top of the board that you should check. Oherwise, these have a solid state protection in the power supply on the main board, that a power cycle should reset.
If that doesn't fix it, you may have zapped it hard enough that the only solution is a replacement motherboard.
Old 12-29-16, 06:33 AM
I am confident that I did not reverse the polarity as I only disconnected the negative on the battery. I checked the fuse in the board and it is good.
When I disconnect and reconnect.. does the order matter.. AC first then batt, reconnect batt first then AC...
Old 12-29-16, 04:59 PM
Honestly, the order doesn't really matter with a Vista clone. Most people do AC first, then the battery.
Old 01-03-17, 07:23 PM
Found the issue.. I was still in programming mode.
Old 01-04-17, 10:32 AM
C
Received 43 Votes on 40 Posts
Thanks for posting back to let us know.
Old 01-04-17, 02:35 PM
It should have occurred to me to ask if you had exited programming mode. That little mistake is far more common that you might think...
