Zone Fault troubleshooting
Old 01-21-17, 11:35 PM
B
MrRon,
How to I troubleshoot, work through a zone fault? Changed the battery and still showing a fault. Thanks you
Old 01-21-17, 11:46 PM
Received 3,409 Upvotes on 3,059 Posts
A battery fault is different from a zone fault. Most zone faults will say "check Z?" or "fault Z?".
What is shown on the keypad ?
Old 01-22-17, 03:05 AM
C
Received 69 Upvotes on 63 Posts
Also, please ALWAYS tell us the make and model of your control panel. Different panels and keypads have slightly different displays for zone faults.
When mentioning a problem of the zone, MENTION the ZONE NUMBER, and what's on that zone. A fire/smoke sensor zone, for instance, is treated differently than a window or door zone.
It makes a difference whether the zone is hardwired or wireless. With most panel models, any zone number above 8 can be either. Working with hardwired zones is different than with wireless sensor/transmitters.
Alarm systems are, by their nature, all custom-made. It speeds the troubleshooting process when you tell us what you're working with.
Old 01-23-17, 06:13 PM
B
Fault zone 13
nx8v2/148E-RF
Garage door
Wireless contact
Display reads Fault Zone 13
Thanks for helping me.
Old 01-24-17, 06:24 AM
B
Check/replace the battery in the wireless contact.
Old 01-24-17, 07:59 AM
B
Changed battery with Zone 14 to make sure good battery, Zone 14 working, Zone 13 still saying fault- reads 13 Fault left shop roll up.
Old 01-24-17, 06:59 PM
Received 265 Upvotes on 244 Posts
If you have replaced the battery with a known good battery, and you are certain that the battery cover is properly in place, then the only thing remaining is a failed transmitter.
It's an electronic device, and it sounds like it may be in a harsh environment (by electronics standards a garage is rough).
Old 02-04-17, 07:20 AM
B
Turned out to be bad heavy duty magnet contact
Replaced the garage door magnet and all is good. Turned out to be a bad magnetic contact. We flooded back in August of last year and I assume corrosion set in to wiring of magnetic contact. Thanks for all your help always!
Potter Amseco ODC-59A Overhead Door Switch
