need help connecting DSC TL-250 to existing DSC system
Old 03-09-17, 07:30 PM
I am planning to connect TL-250 to my existing home security system which consists of
- PC5010
- 4 zone expanders
- siren (the large one)
- 6 keypads
- PC5204
- 3 wired smoke sensors
- 3 motion detectors
- wireless PC5132433 receiver
- 2 backup batteries
I only plan to add a few wireless flood sensors to the system. TL-250 I took off my previous home system so I am familiar how it works.
My question is what kind of power supply do I need to hook up the TL250 and do I need another battery as well?
thanks!
Old 03-10-17, 03:22 PM
Received 25 Votes on 24 Posts
While you have a _lot_ of stuff hung on this system, the PC5204 along with the panels native power is probably pretty good. It wouldn't hurt to do the math to see if you are still doing ok for system power. What is the total Ah of your batteries (if you have them in parallel, just add them together. If you are using 1 battery for the 5204 and one for the panel, you may need to go to a heavier battery (if your current batteries are 5 Ah, go to 7Ah).
Old 03-10-17, 03:54 PM
I took a closer look at the panels and realized the PC5204 is powering everything except the PC5010. so theoretically I can just connect Tlink straight to the PC5010 Aux, right? All my system is powered by the PTC1640 power supply (40 va).
the batteries are 1 for 5204 and one for 5010. the capacity is 7 ah each.
and would I be able to make the PClink cable longer (the one I have is 1 foot and I need at least a couple of feet)?
thanks Ron
Old 03-10-17, 06:20 PM
I have a 6 foot serial cable that I use for stuff like this, so I don't have to perch on a ladder with my laptop.
Yeah, you should be able to power the device off of the PC5010 power.
Old 03-10-17, 06:36 PM
thanks Ron, appreciate your help!!
