DSC Wt5500 Alexor Wireless Keypad
Old 03-26-17, 04:37 PM
Just installed the Alexor wireless system yesterday The wireless WT5500 has the trouble light lit. Upon checking status says battery low even though the batteries I installed were in a new package with the kit. Changed out the batteries with two new different sets and still the same problem.. Is the keypad defective? The trouble status light is also lit on the main 9155 console and don't know if it is referring to the keypad or the main battery.
Old 03-26-17, 05:54 PM
Have you given it 24 hours? Sometime, due to the way that battery test mechanism works, it may take a day to register a fully charged battery.
Old 03-27-17, 01:18 PM
Dsc wt5500
Did a hard restart and a soft restart and can not get rid of the low battery message. Main battery tests at 14.3 volts. Tried three different sets of batteries in the keypad. No luck. There are no wireless devices enrolled now. Can not get the Blue LCD screen.
Old 03-28-17, 02:57 AM
Are you using the keypad on just battery power? I think the backlighting (that makes the screen blue) doesn't come on with just battery power (for power saving purposes).
Install manual for keypad: http://www.alarmhow.net/manuals/DSC/...on%20Guide.pdf
Old 03-29-17, 09:01 AM
Dsc wt5500
Thanks for the keypad information. Was checking the voltage on the main battery disconnected and found it was only 10.5 volts, so ordered a new battery.
Old 03-29-17, 09:05 AM
Shadeladie's Avatar
Super Moderator
I sent you a PM recently. Please read it and respond. Thank you.
