How to program function key 'D' as audible panic
Old 03-30-17, 02:35 PM
I have vista 20p panel and 6160 keyboards. How do I program function key 'D' for audible panic? I have already programmed A, B & C keys for alarm away, night stay & time display. Thanks.
Old 03-30-17, 07:53 PM
Received 25 Votes on 24 Posts
Installer manual: http://www.nationwidesecuritycorp.co...all-Manual.pdf
Normally the B key is the panic key. When you change the function there's no way to make one of the other keys do that function (which is also done by the * + # combo).
Old 03-31-17, 06:15 AM
Unfortunately, those function keys are limited to only certain functions. Buttons A, B and C can be set to panics but the D button cannot. Also button A, can only be programmed to Zone 95 panic, button B can only be programmed to Zone 99 panic and button C can only be programmed to Zone 96 panic. However, as you can edit those zones 95, 96 and 99, you can set those top three buttons to the specific type of panic you need (fire, medical or police).
You'll probably just want to re-map one of the functions you have set to buttons A, B or C to the panic you want and then make button D do the function of the existing A, B or C key that you will change.
Old 03-31-17, 08:30 AM
Thanks guys. I guess I have to program one of the other keys for panic.
