DSC RM-1 relay
Old 03-31-17, 06:54 PM
DSC RM-1 relay
I planned to use the RM1 relay to invoke opening garage door using WSL909 wireless key buttons, there are 5 wires on RM!, Red for (+) Aux, Black for PGM, White for COM at garage door motor and not sure yellow or green (which one?) for other garage door terminal?
Thanks,
Old 04-01-17, 07:36 AM
Received 1 Vote on 1 Post
Yellow is the normally closed contact, green is the normally open. If you just plan to connect this in place of normal manual button for the opener, you would use the white and green.
It needs to be set up so the relay only closes momentarily to open or close the door.
